Use this procedure to create a MAC access list or add a MAC address to the existing MAC access list.
  1. In the navigation pane, expand Configuration > IPv6.
  2. Select FHS.
  3. Select the MAC Access List tab.
  4. Select Insert.
  5. Configure the parameters for the MAC access list.
  6. Select Insert.
MAC Access List Field Descriptions
Use the data in the following table to use the MAC Access List tab.
Name
Description
Name
Specify a name to create a MAC access list.
Mac
Specify the MAC address to add to the MAC access list, in (xx:xx:xx:xx:xx:xx) format.
AccessType
Specify allow or deny. By default, the access type is allow.
